Vumad
Super Hero, with a cape!
- St. Pete, FL
I put a sbt wear ring in my b1 because the stock one was destroyed when i gpt the boat (changed the prop to a mint one i had from jetmaniac). I am pretty selective buying sbt parts these days, but Ive heard plenty of people claiming great results with the sbt wear ring and have had friends who swear by them. This is my first wear ring.
I have probably less than 10 hours on the ring. Last time out the driveline started making noise and no power. Ski was excellent until then. I pulled my pump and the wear ring just fell right out. The outer portion is smooth but slides right in and out now. The inner portion has some rub from the prop. Bearings seem tight and smooth and shaft seems straight. I do spray everything down with wd40 after riding in the surf which has been probably 2 or 3 times over the last 3-4 months. The rest is fresh water, no lube. Prop seemed to spin smooth with no significant rub.
Anyone have similar experience. Could it just be a defective ring or have i been misguided on the quality of the part. Could the wd40 have damaged it (it already has signs of developing corrosion so not being able to treat it would suck.)
