I just picked up a cheap chinese copy scooter. 50 cc 2 stroke. Cleaned carb/gas tank and some other little stuff. I removed the auto fuel shutoff thing and converted it to premix. I just have the oil hose that goes to the engine blocked off.
I wanted to pull the side drive cover off and remove the pin holding the gear on the oil pump but the bolts are on there good and I have LIMITED tools here. If I just leave it will it seize up because of no lubrication?
Can I just leave it?
Or should I buy one of those impact screw drivers here to get it off?
