Seadoo hx 951 zeeltronic questions
I believe i have already tried somewhat of what stock shows but the R&D pipe doesnt seem to work the same as stock, if i put the manifold fitting out the pisser it shoots a strong stream b
I believe i have already tried somewhat of what stock shows but the R&D pipe doesnt seem to work the same as stock, if i put the manifold fitting out the pisser it seems to take all the pressure away from the rest of the cooling, so the first exit doesnt flow anything and leaves the whole pipe to get hot. Idk if i need a restrictor in the system or what? Btw im doing this on the water hose.
The Timmer
killin sj's
metro detroit
Update****
The earlier 98 951 runs a mag cup with 2 trigger lines 180 degrees apart, I've sourced one and collecting asap
I will then need to dial guage the pickup and program the zeel, then good to go
Hello Steve,
I am doing a similar project with a 951. Did you test your system with the mag cup with 4 protrusions? or did you change to the 98 with 2 protrusions long for the final result? anyway that you could perhaps share a snip of your final parameters? thanks in advance, Tim
The Timmer
killin sj's
metro detroit
Tim,
Call or email Jetski Solutions. They sell complete Zeeltronic Systems for the SeaDoo 951 Engine. John can probably help you with the Programming...
LOL This was actually made for me....I use JSS for all of my electrical needs. I am only trying to gather past experience from folks that have used the equipment in the past. Any knowledge I can gain prior to testing in the spring is my goal.
