- prescott arizona
Hey guys I have a single channel msd total loss setup on my dasa 1200 and the led doesn't work so I'm trying to check my static timing with a timing light off the front cyl, but I'm getting inconclusive results. I have the dip switches set to max timing, and the pick up plate pretty far advanced and the light is only showing 20 degrees at around 2500rpm. I'm aiming the 30 static timing, any help or insight would be appreciated
