Shock pad stock sj hood
Just got a new 2014 sj. I'm trying to figure out what's the best shock pad for it with the stock hood. It has the fire extinguisher on top of the hood making it awkward for a pad. What is everyone else doing with the stock hood? Putting the pad on the pole? Using hydroturfs premade one? I would love to run a thicker one! Ideas and suggestions would help
Fro Diesel
creative control
Kzoo
Do a search in the parts section. There is a guy that makes some really cool custom pads.
Pretty sure that was Zimmy.
I use two layers of 26mm and sand with super coarse sandpaper wheel to make edges squared and rounded. put the thicker pad on the pole.
What are shock pads typically made out of? I was thinking of using my underpad and turf to just make a square one. Or for those ones that have cool designs on top, are they just getting some sort of foam from the fabric store?
Byeai
"Cheetos-Man"
Melbourne FL
Honestly I had one that was made from black underpad but swapped to pfp blocks work perfect
I might just use underpad with turf all around for now. How tall should I make it? I don't want it to be too short but I feel like if its too tall its liable to get ripped off during a sub or something?
CRJ
Hibernating
Toronto
I used the thick underpad only. Works good. glue two together if you need higher thickness.
