Powerhouse
okay
- Florida
What does the process of shortening a drives shaft involve? Would you simply cut off the end, and cut new splines into the shaft? Has anyone ever shortened one before?
Most people are trying to go longer but surfersmurf is right, the splines are on a larger diameter than the middle of the shaft. There are various sites that sell all the different driveshafts for various ski's. You may be able to get something close to what you really want without all the trouble. Don't forget, when you cut a shaft, it heats it up drastically and that heat will change the strength and stiffness properties of the metal.
send a pm to jetmaniac,
When I cut splines in driveshafts they barely heat up at all. Powerhouse, what length do you need? Smurf is right about the SJ shaft, but not all yam shafts are smaller. Some are larger.
Send it to someone that does it. Give them the exact overall length, and pay roughly $100. PM me if you need more help.
why noy just cut it out of the middle and reweld???
if the current splines are still in good shape,this is the way to do it,use a slide over collar. why do you need to shorten the shaft that much,sort of a odd request.what kinda hull mods are you using for this
Most likely trying to use a shaft froma couch so that he/she wont have to go buy another SJ drive shaft.if the current splines are still in good shape,this is the way to do it,use a slide over collar. why do you need to shorten the shaft that much,sort of a odd request.what kinda hull mods are you using for this
