- Acworth, GA
I have a perfectly fine running stock B1 that goes 44 but I have free access to a 760. I hear I will lose bottom but gain top, which is an issue as I surf ride. I was also told that a 61x exhaust mani will require helicoils and I don't want to go down that road. Next option is to use my 701 FP....will that bolt up or do I need helicoils for that as well?
Is there anything else to be concerned with? Should I do it?
I also know I need to swap couplers and remove the rubber piece on the bottom of the 760. At first I was happy with the increased HP I'd get but now I'm wondering if I'm messing up a perfectly reliable stocker.
Thanks!
Thanks!
