- louisville ky
I was riding the ski yesterday and subed it and went to dry it out at full throttle then womp ,stopped with a quickness. trying to start and crank then buh crank buh .crank crank crank buh ..u get the picture ..any ways started to check some things and looked like my skis fuel filter was not getting full ?? Crank and it fired ran then womp stopped like it did after the wide open run ..I get it home check the check valve on the tank .I blew air in and no air should come out right ?? Tank should have pressure right or is it the other way around .the second thing I checked was the start and stop switch .on the landyard switch the little plunger was loose should it be ??
