rehak2
Here we go again!
- Lino Lakes,MN
Tried to do some research out there to see if anyone else might of had the same issues but didnt find any.
I got a rn sj with a ported 701, b pipe, 46mm carbs, ada head, 12-17 prop. I just had the carbs gone through with new parts and also went from a 14-19 to a 12-17 prop. I ran great for the first 2-3 rides. Now if I give it half throttle it bounces off the rev limiter. What could be causing this? Compression is good and even, tried new plugs, tuning the high jets with no results. I am running a stock electrical setup. Bought this ski not running found out it had a bad msd enhancer in it, switched to a stock cdi and has ran great until now. ANy ideas? Coil maybe?
I should also add that this also happens when its on the trailier also. Tried it once and at half throttle it cuts out.
