I am getting into freestyle on my 1990 sj and I want to tighten my Handel pole so that when I put it in one spot and let go it will stay in thAt spot.. Anyone know how to do it without cracking the pole or the brackets that the pole is bolted to
Thanks!!
That's a bad idea with the stock pole and mount on that model. The mount is cast aluminum, and can crack. The pole doesn't take flexing well, either. You might be better off with a Hazard Bracket and a RN pole.
