- Lexington Ky
I have a '97 Sj that is giving me some problems. It will start and rev clean and nice on the trailer. When you put it in the water it will not rev past 1/2 throttle and is very choppy. If you go in circles and get the exhaust out of the water it will pick up speed then completely shut off.
I have replaced:
fuel lines
fuel
fuel filter
carbs
reeds
coil
ignition box
spark plugs
After replacing all of these the problem has not changed even a little bit. Still exactly the same. I am at a loss of what to try next.
I have replaced:
fuel lines
fuel
fuel filter
carbs
reeds
coil
ignition box
spark plugs
