I went with new OEM SJ mounts. It solved my engine angle and height. I actually have marks on the bottom of my old hull from couch mounts flexing and my case bolts touching.What I have read about SJ vs couch mounts is that the SJ mounts were a carry forward from the 650 61X engines. They're adequate to handle the 650's power and reasonably well suited for a stock 701 on a 61X base but when they moved over to the stock dual carb 62T 701, that's where they max out their limits to resist vibrabtion and directional movement. When the freestyle/freeride side of it took hold and more people began looking for bigger and better power upgrades the mounts became less and less capable of withstanding the power output and bigger air landings. I have spots on my old Kenny Keepers where my engine moved forward from doing stabs and it impacted the keepers. Once I swapped the mounts out to couch mounts that no longer has been an issue. I didn't have to do anything to the mounts either. Put them in place loosely, set the engine on them and slide it all around until the engine aligns properly to the coupler. That's all I needed to do. After that, take one bolt out at a time, blue loctite, put it back and repeat to the rest, pull the engine out enough to put the damper in and bolt the motor down after a quick realignment. I still have my stock mounts but probably won't ever be putting them back in.
Just buy whatever is sold in the gas station when getting fuel, so you know they are compatible…What type of oil should I be using ?
Nope.......you really need to check the owners manual. starting in the 90's a lot of manufacturers were starting to use 5w-30. You just need to make sure that's what yours uses!Just buy whatever is sold in the gas station when getting fuel, so you know they are compatible…
better to foul a plug than buy a jug !Nope.......you really need to check the owners manual. starting in the 90's a lot of manufacturers were starting to use 5w-30. You just need to make sure that's what yours uses!
