spookyjjj
Back @ it
- Billings Mt
Yes they put pert near the same pressure with dual cooling. Question are you saying your going true dual cooling, two in from pump and using the bilge thru hull tube for your second line in from pump thru bulk head?I think I'll tap the exhaust manifold for dual to keep each cylinder even and use my stock bilge to feed from my mag pump and all should be good. I was getting overwhelmed looking how people water route their skis and I have always done the Fp method but I never had a head like this. Does one put out more pressure than the other on the head?
Yeah I was think about it. I don't really run too hard and the mountain water stays fairly cool here in montana. My riding is on a river with a bunch of Braap Braap Braap. So some say I don't need a true dual cooling but who knows lol my ski doesn't run hot and feels great. I never checked temp coming out of pissers before though.Yes they put pert near the same pressure with dual cooling. Question are you saying your going true dual cooling, two in from pump and using the bilge thru hull tube for your second line in from pump thru bulk head?
I run my out line from the head to the lower fitting on the headpipe, then out the top. reason being, it fills the jacket from the bottom, this gives plenty of pressure for the spray holes inside the manifold to spray water into the exhaust. If you enter from the top, you can loose some pressure with it existing the bottom......
