- Austin
Good prop for my superjet? Cant seem to find anyone running it. Is it worth $100?
It's a good prop but maybe to much for a stock sj but for a ported motor with a pipe it's fine.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Yes if it's to big for ur current setup put a washer behind it and loosen it up a bit. A stubby pump cone or bored nozzle works good too if it's to big.
I would put your $100 towards the correct impeller.
make sure its not worn out and needs a resize for $125
