Ski bogs
Not a mechanic. Ski usually runs good and is responsive first or two jumps . Seems like when I go over a few boat waves while throttling it or come out of a slide - when I hit the throttle it bogs down . If I feather throttle , it usually catches and rpms increase . Carb, Stator - Ideas ? .
When I throttle it at first - goes like a banshee . Seams like after I throttle it a couple of times , the starts to bog . Also , after coming out of a slide , bogs at first - then clears up for a while .
Midlake Crisis
Bakersfield, CA
Check your hood seal, especially if it is happening after hitting wakes etc. you may be getting a big spray of water into the engine compartment each time you splash down.
Checked fuel filters - clean . Drained what I think is a water separator - a little bit of slimy residue drained out which smelled like fuel . I do have a very small leak in exhaust which lets small amount of water in bilge but I have two bilge pumps . Ran ski yesterday and today with very little bog occurring .
