Ski runs like crap when the tank is full, but it runs better when empty?
Roseand
The Weaponizer
Wisconsin
You might have a look at the fuel cap and seal while your in there, @rubbertoe brought up a good point about water entering the fuel system while the noise in submerged
Yeah I'll check that out. I'm really curious if I remembered to tighten the filler next on the tank, cuz that would describe what propulsion is saying too..We'll see when I get out there later today or tomorrow. If water did get in the fuel system, I should be able to see it if I siphon the rest out, right? In my experience though, cant you see water in the bottom of the fuel filter as well?
Stockton
I do fuel samples at work, take a sample from the entire bottom of the tank, siphon a little off the bottom on this side and that side, the middle and put it a clear plastic bottle and let it sit and separate.
How much fuel you got in the tank, I think I'd just pull the tank and poor it all out into a bucket and let sit and check the tubes and such while it's apart.
Edit: should mention safety. Fuel molecules are heavier than air and will collect along the floor, most oftener ignited by the water heater pilot so be careful
Roseand
The Weaponizer
Wisconsin
Yeah I know Whatcha mean. I've got a siphon at the lake that I can get everything out of the tank without pulling it so I will definitely do that. I probably only have a gallon or so left in it. Don't like pulling the tank if I don't have to :p
I swear, when building a ski a cart tank would be a nice thing to have when working out kinks lol. My tanks a pita to get out.
Roseand
The Weaponizer
Wisconsin
Drained all gas, no water in it at all. There were a couple spots on my hoodliner that I knew leaked, so I gorilla taped those seams(it's always leaked a little, but never caused an issue, and were near the hoodhooks/nowhere near the carbs). Started with a little over a gallon, after I let it idle/rode around at a low speed for a minute or so it was a little sluggish, but a little more pegging it and it was all cleared out and ripping perfectly. I'd do a stab, no issue. Filled it up more, didn't feel as snappy but still very good. Filled it all the way up, and rode it around, finally a boat making a decent wake showed up(it's like 50 degrees here, not many people are out), and I did some nice stabs and went deep like always. I'd recover and there was no delay, no clearing up. Just ripped like normal even with a full tank. It did feel a little snappier with one gallon in it but that might be my imagination, or Cuz it was a little lighter. But it has been running pretty damn good. Soooooooo weird.. Running like normal now and I didn't really change anything. But it had those same crazy symptoms for two tank fulls.
rubbertoe
X-H20 certified
San Diego
That escalated quickly.. Yes I have had water in my gas before.. I'll siphon the rest of the gas out of my tank and check to make sure it's sealed and see if there's any water in it.
Why 4 pages? Because it's a different issue than I've heard of before and obviously it's something people have had to do some thinking about, and people have been willing to help. Stubbornly refused? I'm not stubbornly refusing anything at all, i rule out stuff that doesn't make any sense and I try to think about how that issue would actually cause my symptoms. I like to critically think rather than just trial and error but that's just me.. @Harbor and @Pro-pulsion do the same.. Maybe I forgot to tighten down the hose clamp on my filler neck, so after an impact(when the tank is full) it partially slips and the pressure leaks out, and when it's close to empty it barely after an impact. That would cause propulsions theory if it wasn't a fuel pump issue.
@rubbertoe, if it was still summertime I'd be constantly trying different things out and wouldn't be chattering but I have zero time to work on my ski during the week, and very limited time on the weekends.. So IMO it's good to have a bunch of ideas brainstormed to problem solve what's going on during the week. There's been some awesome ideas raised here..
Don't know why you had to freak out about it. If you don't wanna hear about what's going on, then don't click on the thread and take out your anger. Not cool man!
Rosand no anger dude,and not being a d*ck .its just these aren't super highly complex machines with quirky minds of their own there actually relatively simple system machines ,im just trying to figure out if you just like to post to the community as a pass time or you are genuinely trying to fix your issue ,is all .not mad dude i would like to hear that your stuff is good .but if your not willing to follow a process and you just want out smart your problem "on line" with out actually trying some of the suggested fixes iit could be a long road .my 02 cents don't hate on me as we head on page 5 with no progress
rubbertoe
X-H20 certified
San Diego
so your saying its running better after you changed the fuel ? maybe it helped .did you try to pressure test your tank ,also how do your pulse lines look .if nothing more it will get you looking at areas that may need attention anyways on the way to a completed repair ,at least thats what i find .a lot of times when i have an issue it gets me looking at things that i might have not given any attention to in a minute .don't mean to come off brash .
Roseand
The Weaponizer
Wisconsin
Sometimes you can get confusing problems though, even though they are fairly simple machines. I've been trying to fix my issue..not just trying to pass time. No worries man, but I think you're misunderstanding my processes. And there's progress..I checked a few things out today and now it's running normal. I didn't do anything drastic, which makes no sense.
Roseand
The Weaponizer
Wisconsin
Yeah, but it's wierd! Because for two tankfuls it had this issue, and each tank was from a different station.. Today I got my fuel at the place where I mix 4 gals of 93 with 1 gal of 110.. I didn't pressure test my tank, but I did have the fuel pickup system completely out, checked all my fuel lines, took off and drained my fuel filter, etc. Fuel lines still look really good. I didn't see anything abnormal, so it's so so so so wierd..
And no worries, you're all good man
rubbertoe
X-H20 certified
San Diego
Cool man .sometimes something as simple as a cracked fuel filter can cause issues,this season i had air get in my fuel lines due to the fact that the fuel line i was running lost some of its elasticity ,caused poor performance some simple zip ties and was good .so no question is bad question its just nice to know when headway is being made .
Roseand
The Weaponizer
Wisconsin
Yeah fosho, but I found absolutely nothing wrong today but somehow it went away. Strangest thing..Let's hope it stays that way!
That's awesome that things cleared up bro. It makes me think that since it cleared up and is back to normal then there had to be something partially plugging the fuel system...one thought in particular that came to mind just a little while ago is that if your ski did take a drink from a stab or something that would get the flame arrestor in a position to snort some water, it could sit in the base and mix with the oil. I have seen it happen a lot, with the different blends of oil from the different oil manufacturers some blends will mix more easily with water and froth up into a thick and tacky blue foam. It fills the trenches of the cases and also gets slung into the pulse port on the cases. Just the loss of case volume from the blue foam will reduce pulse signal until it finally washes away with the repeated clean fuel throughput. I know that my Lucas semi synthetic likes to froth up and after seeing how it reacts when water is introduced, next year when I clear out my supply of Lucas I will be going back to the Castrol Super 2-Stroke Marine. I never had an issue on that stuff and found that it even helped clean carbon deposits when doing tear-downs. Plus it is very affordable compared to the Lucas. Glad to hear it's working out for you dude.
Roseand
The Weaponizer
Wisconsin
The first time this happened it was when I was out of klotz and ran some cheap Walmart quicksilver oil that was 20$ a gallon. I read on here that people had good luck with quicksilver, so I didn't think it would have that issue. I ran 5 gallons of that at like a 32/1 mix(Just cuz it wasn't a nice synthetic like klotz, so I richened it a little bit) on the flat lake, and then another tankful of it on the big lake when I had those symptoms.
Even with a full tank of klotz mix, it still took over an hour of riding for it to finally get better(It felt like the same symptoms I had while using quicksilver).
If the froth was the issue, then it took over an hour of running with good oil to clear it up.
I'm running a one way valve off of my tank with some hose and then that plastic bulb/tube contraption. I believe that tube moves up and down to prevent water from getting in, and maybe it was stuck ina position that wouldn't allow air to get in? I moved it around today just for the heck of it.. Maybe that's it. IDK lol.
That could very well be what happened. My ski has the same tube but mine doesn't have a ball inside, it just has a small hole drilled through both sides at the end of it to limit the amount of water that could get in there. If yours has a little ball in there, and mine doesn't, then that would seem to me that they had issues with your ski's style and changed up to the version I have. I just keep mine tucked in with my fuel tank strap on the exhaust side, never had any water issues in the fuel and without the ball inside, never had an issue with that either lol.
Roseand
The Weaponizer
Wisconsin
Yeah mines a tube with another tube through the middle that you can slide in and out, and I must have had it slid so the holes were sealed off..
Hehe, nothing like the simplest thing to become the worst issue. I was going to say earlier that what you should try is just walking away from it for a few days, go play with the gf or something and get your mind off of it. Then when you come back to it you will have a cleared mind and different view of what to think or look at. I find that this is the best thing for me to do when I get to a point of frustration and seemingly endless variables to try. Take a good break and come back later in the week, seems to work more often than not =)
Wisconsin
No way mine could ever seal off those holes. Its just a shroud to deflect water I don't think it has that function.
OCD Solutions
Rentz, GA
What about the fuel pickups touching the bottom of the tank and sealing off? They may be sitting higher after you reassembled it this time.
