DylanS
Gorilla Smasher
- Lebanon Pa
Completely stumped on this one
Had my 66e 1050 at the lake last week
Starter takes a dump
Bring it home, replace starter
Notice one of my veins is snapped
Assemble new stator and replace in ski with a oem prop spacer this time (none prior)
Get it out to the lake Next week and the ski is running extremely flat
Just no power whatsoever
Motor sounds fine, just won’t rev up
But when I get the pump to unload slightly the motor seems to rev up for a brief second then die back down
Sounds like something is major holding back the motor
Feels like riding a oem 650
Ski keeps running away at idle out of water with no leaking Venturi
I have
-cleaned the carbs, replaced the seat o-rings and needles on both, tried several different pop off pressures
-made sure I had no exhaust obstructions
-new plugs
-verified MSD TL was firing both plugs
-verified my stator plate hasn’t shifted in any way
-tried fresh gas
-verified compression is good
-verified butterflies opening at same time
Ran perfectly fine, sat a week, get it out and it refuses to run right
No changes to jets or anything of the sort
I have considered that it is the prop after spacing it away from the stator but the ski doesn’t vibrate/rev up, no cavitation
Did have the TL system on for a few hours before I remembered to shut it off, but I haven’t seen one go bad without outright refusing to even fire. Have also run same prop with a spacer before and it seemed to be better. Would not rule out a electrical issue.
Any suggestions? Going to do a leak down test again when I get home to rule that out. Seals only have a few hours on them. Can not find anything out of ordinary. Anyone have anything Similar happen?
I have
-new plugs
-tried fresh gas
