Sleeve Removal
What's some techniques for removing cylinder sleeves.
Have to replace a sleeve in a DASA 1100.
Need to start doing these things myself as I have to freight to the moon and back at the moment.
Sent from my iPad using Tapatalk
With stock cylinders I just put them in the oven at 400 for about 20 minutes. But. Check and see if the process is the same with after market cylinders. But don't use a press.
Yup, you can use a gas grill and do it outside also. Crank it up on high and let it warm up, put cylinder in for 10-15 min. I would remove one dome from your head and put it on the good sleeve, and use a piece of scrap steel to span over it and drill two holes so you can bolt it on each side to clamp the sleeve in place so the good one doesn't move. After it's been in there for a bit, pull it out using welding gloves or similar, flip cylinder upside down on the bench onto some wooden blocks and the sleeve should slide right out. You'll want to clean the cylinder inside mating surfaces and check for damage.
You probably want to port your new sleeve most of the way before it is installed...and check deck heights as well. Then put sleeve in freezer and heat cylinder. You have a bit of working time this way. Drop the sleeve in and line up ports quickly, then clamp a head or something down to ensure it stays put. You will need to check that the sleeve doesn't protrude from the cylinder, you will probably need to deck the top. Then finish porting and get it bored, good to go!
Best of luck!
Don't understand that theory either.
400 degrees seems awfully hot also, I do a lot of heating/cooling at work with bearings etc and will never go over 275.
Is this correct?
Less working time by freezing the sleeve? How so?
I've done it both ways. Because aluminum has something like 5 times the expansion / heat dissipation rate as steel. Freezing it does very little to shrink the sleeve, however the much lower temperature of the sleeve brings the aluminum cylinders back down below the threshold of the interference fit more quickly.
