masterblaster
X-H2
who sells these now? cant find him here.I get random click from mine, anyone else have this happen on older ones?
I just had one go out after about 50 hours. Start button would start ski with no teether. It also killed my battery. So if you run one make sure to have a quick disconnect on your battery or pull the fuse to brain.
this would be start stop issue rather than solenoid wouldnt it?
Buzzard, guess one relay with multiple contacts makes starter relay contact but not the ign on contact. Mine still clicks when the off button is pressed,but wont engage the starter relay
I had just assumed it was solid state , not a mechanical relay- now I'm worried. It looks like a latching relay presumably used on a car with a folding top.I opened up my shifty module, its a 12VDC self latching relay, so it should only hold ignition on, when you hit start button. The idea is great.
I got fed up, when mine crapped out that fast, a day at the lake with 30deg C weather, and a enclosured box with MSD, that require you pulled engine out - just to pull out the module and run hardwired. No issue since.
I used to run wing nuts on my battery so you could change battery with no tools.
Also i run a MotoBatt mbtx9u 9ah battery and a 5ah Li-ion battery. Both battery will last around 30L of fuel, a good day of riding.
Its not, coil relay. Double latching i think its called.I had just assumed it was solid state , not a mechanical relay- now I'm worried. It looks like a latching relay presumably used on a car with a folding top.
