Smoke from bottom of motor
superjetguy
It's hard to speak without a tongue.
lake hogan
Hey guys I'm getting smoke from the bottom of my 650sx motor where a little choke like cable goes into. What is this? And is this and is this a common problem? How do I fix it?
Not sure, may not be worth the risk. Id be waiting until the block off plate is installed.
Sent from my Nexus 5 using Xparent Red Tapatalk 2
You can pull your motor , take the case drain off, pull it appart , I believe its three pieces. One of the pieces , I believe its the outer one can be flipped over and bolted back on by itself and it blocks it off just like the one you ordered. Use 1211 in the drain holes and on the plate your bolting back on. Done.
Or get a couple short bolts and thread them into the holes. Fill the holes with 1211 first , no need to tap with the correct bolt , just thread it in . Done.
Its a two stroke. If you get water in it you can drain it and restart it and ride it like you stole it to dry out the crank bearings. If you ride it like it is you will melt pistons.
