Vumad
Super Hero, with a cape!
- St. Pete, FL
If it's a stock exhaust, it's going to have a lot of water coming out of it on the hose. There's no way to see how much water is coming out of it in the water so you must be doing it on the trailer. Running the stock motor and pipe on the hose for about 30 seconds, then hitting the throttle, it's going to dump loads of water out. It's designed to be quiet, not work good. It's probably not excessive. It's just stock.
You did not answer the question about the tilt. Does the thing die as soon as you tilt it even at an idle? Or does it die when you give it gas? Does it run okay strapped to the trailer in the water and continue running when you hit the throttle? Can you put the ski in the water, put the nose up against a sign or some other stationary object, keeping it flat and hit the throttle?
The tilt is probably not related in any other way than you have to tilt it before you ride it.
