Have a few updates on some more testing with this impeller. I finally got my y62t zeel in and am running the default wax v3 curve. The other notable change is with my steering setup - switching to an OVP straight fatbar and trimming the blowsion HD cable end to maximize nozzle throw. That moved my bars forward just under 6" and gained significant nozzle throw in both directions.
I noticed a significant increase in bottom end all the way through 2/3 throttle. It was pretty rough so I didn't get too much time testing up top. Max rpm is still right around 6890 so it looks like I will need a little impeller work.
Is my target rpm actually 7k for this setup? If so I assume bending the last 1" or so of the trailing edge up to 15 should give me that 120 rpms I'm looking for. From my notes that would also take the gap from 1.4" down to 1.3" which should reduce the load a bit too.
