- Minnesota
so you would still need a 148 wear ring as well with an impellor? Did they say if bearing were going to be included?
That is correct. They did not mention anything about including bearings with the pump.
I would like to get mt hands on one of these. Love that fact they are a 2 pc pump. Less to worry about if the prop takes out the ware ring vs taking out an entire pumpWe have been selling the Solas 148mm pumps and 148mm liners in Australia for 6 weeks
148mm liner 1.5kg or 3.3lbs
148 stator with pump cone 4kg or 8.8lbs
They dont come with bearings or seals, make sure you use Japanese bearings and make sure they are C3 or C4 rated as the stainless housing has a tighter crush than an OEM alloy housing.
Whats the price?We have been selling the Solas 148mm pumps and 148mm liners in Australia for 6 weeks
at that hella cheap price i dont think it mattersAre these setback or non setback?
$1100 is hella cheap...?at that hella cheap price i dont think it matters
That would not be a setback stator...Are these setback or non setback?
MSRP is $1100... big difference$1100 is hella cheap...?
how much did your pay for your NEW solas 144 @Matt Jonesbig difference between??
