- Rincon Beach
The Rickter hulls have a small divot /dent in the firewall right where the midshaft housing seal is supposed to seal flush, if this has not been addressed during your build you will have cavitation issues
We typically bond our midshaft spacer plate to the hull with 5200 ,this than gives a perfect sealing surface for the midshaft housing and moves the bearing carrier forward so it is not hitting the firewall causing damage
Db
Db
