- Atlanta
2014 Complete Rickter Edge Freeride For Sale
NO TRADES OR PARTS SOLD SEPERATELY
Hull 2014 Rickter Edge FR model all fiberglass. Originally came from T.C. Freeride. Florida Titled as California Homemade Boats. I was told its actually a 2016 model but titled as 2014.
RRP Ninja fully adjustable footholds.
RRP Rear removable rear sponsons.
RRP scupper drain.
RRP intake grate.
RRP rideplate.
Cold fusion hood hooks.
Oem Superjet hood latch.
Hull was just hydroturfed with Oem style Waffle turf by LPW (Lehr Performance Watercraft) Nobody has stood in the tray yet..But a water test is on my agenda.
Blowsion hood straps are bolted up to the front hood hooks and there is holes in the firewall for the other half of the straps to bolt to but I have not punched the holes through the turf yet in case new owner does not want to run the hood straps.
JM ebox bling washers.
Blowsion bildge pump switch, 1 Rule 500 gph bildge pump installed on a blowsion double bildge pump bracket bolted to midshaft housing.
Hood seal is cracking. Have brand new hood seal just not installed yet.
Motor Rebuilt 7/2/19 By Watercraft Factory INC.(have receipt)
Yamaha 701cc 62t cases with 61x Cylinder. (ported for freestyle)
Sbt Crank, Oem seals.
81mm Pro-x Pistons.
Dasa head,stator cover.
Some off brand homemade kenny keepers
Dual Mikuni 38 carbs. (rebuilt)
Brand new JM fuel lines and high flow filter.
Cold Fusion Gas tank with brand new oem straps
Factory B-pipe.
Comes with flush hose attaches to water lines with quick disconnect.
Oem Round nose SJ water box.
Pole is RRP billet model.
RRP chin pad.
RRP steering plate.
RRP fatboy handle bars.
RRP steering ast steering pad.
Brand new odi rogue grips.
X-metal throttle lever.
New used Yamaha stop/start switch.
Odyssey extreme series 220 cca battery.(battery Is still strong and kept charged)
Pump is a clean OEM 144mm Superjet with Hooker prop.(not sure the pitch)
I Just replaced the midshaft with a brand new Oem Yamaha.
Has like new ADA billet couplers and rubber damper looks new
Full RRP trim system with cable and MX-99 trim lever. Trim pulls nice and easy.
Engine compartment was just gutted and everything was hand scrubbed with a toothbrush and reinstalled.
I bought this ski for my friend who was interested in it. He decided not to buy it. So I put some work and money into it and made it much nicer. I already own another Rickter Edge and If I did not I would keep this ski for myself. The ski is used and there is normal chips on the gel coat here and there. It is not a new condition ski. It has been ridden in the surf by previous owner. It has been beached and the paint on the bottom is worn off. I plan on touching it up with appliance paint. I don’t think it was ridden much at all after motor rebuild.
Asking $13,500 firm. Please private message me a phone number so we can talk if you are interested in the ski and want more details.
Ski is Located in Atlanta GA.
RRP scupper drain.
RRP intake grate.
RRP rideplate.
81mm Pro-x Pistons.
Factory B-pipe.
RRP chin pad.
RRP steering plate.
