SOLD -- 2018 Krash 50Cal
2018 Krash 50 Cal
The KV 997 drive train comes complete with 48mm Black Ops spec carburettors, 150mm Black Ops power pipe, carbon reeds, lightweight crank, Pro X conrods, Wiseco flat top pistons, 12 vien 148 setback pump with trim, stainless propeller and lightweight aluminium waterbox.
Updates:
New Zeeltronic Ignition with two preloaded maps
1-2" Padding added to the tray
Custom footholds with 1" Padding and blue turf
Prop Re-Pitched by Impros to 10/16
High Comp Domes (180/179 PSI) - Have stock domes to go with it.
New Motor Mounts last summer
Pole Shortened 3"
New Second Bilge Added
Have Tau Ceti shorty airfilters with adapter plates Installed
New Coil Pack/Wires
Asking $SOLD SOLD
Weight is 315ish I bet. Weighed it a while back and can't recall exactly. The right rider could probably but I've never met anyone personally however any minimal boat wake/surf wake and some skill and you'd be good to go.
Sent from my SM-G960U1 using Tapatalk
