Super Jet Spark Plug Boots
hey Yall, whats the best Boot to replace Stock ones? This Boat sat for quite some time so i wanted to cut back the wires and put new boots on em, wasjust going to to go with NGK for the mean time. thoughts?
I prefer to run non-resistor boots and resistor plugs. The reason being that the screw on terminal plugs always seemed to loosen up on me. The solid top plugs are only available as a resistor plug. For the boots I just use crimp on terminals with rubber boots. I have run the screw on NGK boots before and they worked ok. I would try the NGK PN 8381 boots if that`s what you are looking for. I just switched to crimp on boots as they are cheaper, I already have the crimper for making car plug wires, and I do feel they are more secure.
I’ve got ocd coils with ngk boots and they work just fine. Never have had a problem with them, although I have only put a few hours on the ski.
Stockton
Been using these particular NGK boots since 2003 without issues. Been on my RN for 15 years and counting, But that one posted above looks janky.... maybe it doesn’t work well.... have Msd crimps in other skis, they also work good.
576E172E-8B53-483E-9D2A-3588097C4DCF.png66098BC8-7F66-41F5-B0B3-ED3D03A1481F.pngC0D5D5A1-68D8-4204-BACF-38C66EDA2A0F.png
