- North Dakota
Just getting into superjets, what plug would I use for a 1999 701 that's bored to a 747
NGK BR8ES
NGK BR8ES FOR AFTERMARKET HEAD
NGK BR8HS FOR STOCK HEAD
JUST TO BE CLEAR.
How would a BR9ES do?
JUST TO BE CLEAR.
listen carefully. the (ES) stands for extended. (HS) is standard length, so if you put a br8es in stock head you have a chance of putting a hole in your piston!!. and the number stands for the temp degree, 7,8,9..... hotter plug hotter spark..
