Special Tools
Sanoman
AbouttoKrash
NE Tenn
Got that tool made yet?
Dan,
How's that pipe coming along?Been reading your thread.Since l put the msd on the fx,man it pulls great!Nice power band. You will love it when you ride.And you sent the dam rain up here.lt has done nothing but rain the last few days with 70% sat and sun. later don
FlightPlanDan
Don'tTrustAfartAfter50
Dan,
I've ridden with the enhancer allready and like it alot. Never realized how often the limiter was kicking in when not needed.
The pipe is in, the carbs are re-jetted. Heading to the spot in the A.M. to get it dialed in tight. Also closed the front airholes, opened up the back ones a bit. From here on out it's just "low-budget" mods for a while. But if you watch the featured vid...that guy is rolling etc.. with a 650, a hooker and modest mods...on flatwater.
I've got no excuse with what I've got......with waves....
Here we go!
EDIT: sorry, it's not the "featured vid" . It's "Team insane Videos" in pics and vids. OOPS!
I've got a couple of ground down wrenches. One open end for B-pipe and one box end for R&D and dry pipes.
I've got a notched flathead screwdriver for a battery strap too.
And a bent driveshaft for a coupler removal tool.
Scott has a plate that bolts to the cases that holds the rod in place so you can pull the coupler off the engine side.
Aaron
I usually grind the inside of the worthless 11mm wrench to fit a 12mm bolt and then modify that. I made an impeller tool out of a chunk of pipe with notches cut in the end and a 3/4" nut welded to the other end a couple weeks ago to remove a Solas imeller from a 440. I also made my own FW puller, 1 hole in the middle with a bolt pushing against the crankshaft and 3 that match up to the threaded holes in the FW.
227
Its all about the surf!
Oceanside, CA
How many have ground down a perfectly good 12mm open end wrench to tighten the upper/inner two screws to install a Factory B-pipe manifold?
How many have cut a 12mm open end wrench in half to remove/install dual carbs in order to get more than an 1/8 of a turn at a time?
I've done these things. Wondering what other creative tools are out there!
I have the ground down 12mm for the FP manifold as well as a notched screwdriver for battery straps and a few other "custom" tools I use, however I haven't cut down a 12mm for the carb screws yet- I better get with the program HAHA
cattledog
EH TEAM RACING
toronto canada
good idea i have a bunch of 11 mm i dont think there is a 11mm bolt on a yamaha or kawasaki
