Freestyle speedwerx dry pipe
just joe
NorCal
They are very good, one of the best dry pipes made. Let me know if you pass and he wants to sell it. I sold mine and regret it.
they are the best for creating power and designed by darren hedlund of team kawi. i have had a few of these. they arent the best for freestyle since they mount with a complex bracket system. no dry pipe will take the beating that rolls and flips deliver. i used to get $500 for them, but i wouldnt sell my last one for that, since any new dry pipe is $800+ and not really as good. preferred by knowledgeable racers back in the day.
just joe
NorCal
I think the NYNJA C4 can give the speedwerx pipe a run for its money. Rode one last weekend and was impressed.
Hey I'm after the correct water cooling setup for these pipes, any help would be appreciated.
This is what Ive got so far, The diagram is of a b-pipe i found on here and i have added the other outlet that the speedwerx pipe has (the one with red line through it)
so it would run 3 pissers for daul cooling
Is this correct???
These pipes certainly do work great, i had it setup on my ski before i rebuilt it and it was a big difference compared with stock. Just was running single cooling before now im running dual just want to get the setup right.
yea, thats right, but you just need a sand filter where the flow controll valve is and it doesnt need to be Td, so only 2 pissers.
cheers for that so remove the tee and remove flow control & replace with sand filter? Would there be much of gain to run the flow control?
that sand filter goes between the exhaust manifold and hull. the inline sand filter you need looks similar to the flow valve only its plastic. look on the factory pipe website at the sxr dry pipe. it is the same setup. i dont know where you get those filters new.
Ok sweet, Ive found the inline filters in the Hot-products catalog.
This fitting should have the restrictor jet? mine is not straight like this one it just has a standard elbow
