- panama city beach FL
re assembling my superjet and i installed dual cooling on the pump i have
*44mm a/m carbs(oem airboxes)
*ported cylinders and 1.00mm over pistons by jetmaniac
*riva intake
*speed worx dry pipe
*girdled ada head
i was wondering the best way to hook up the dual cooling have researched and not found a solution i did not tap the top of my manifold but if need be can pull off and redo if you have set this up before (with or without the manifold dual tapped)and could explain would be greatly appreciated
also if anyone has had a set up close to this what jets were you running in your carbs?
*riva intake
*girdled ada head
