Well I am at wits end with this carb. Can't figure it out and need some help.
Stock 650 with coffman pipe and water box.
Removed the large intake box thingy for more air flow. Stock carb 38mm.
Symptoms are not getting on plan or going past 4400 or so rpms. 2 peeps.
I can add a hint of choke and it will run like it should. It has done this since the beginning. I have lowered the pop off. Increased the pilot jet from 58 to 60. Same thing. Went with a 122 main. I had 2 1/2 turns out on the air screw.
Just installed the 125. Have 2 turns out and is worse than before. Add a little choke and it runs great.
Idles great .starts great. With the 122.5 in it , it would pull from a dead stop to 200 feet and fall on its face.
Most I get on choked rpms is 5700 to 5800 rpms.
What does anyone suggest? I am tired of choking my chicken!
Current set up is 60 125. Don't remember the pop off but is lowered.
