Spray paint on engines? Yay or nay?
kalispell
I'm looking to purdy up my new engine with some bling and was wondering if spray paint will hold up to the abuse of being on a engine/inside of engine bay. I wanna do some anodized painted pieces but don't wanna waste my time if it's just gonna flake or peel off right away. I know if gas gets on it the paint will come off but I'm very good about not spilling when I fuel up. Any input from people that have any experience with this is greatly appreciated.
Sent from my HTC One_M8 using Tapatalk
kalispell
Good to hear, was gonna go the powder coat route but the two coaters we have in our area are way steep on prices.
Vumad
Super Hero, with a cape!
St. Pete, FL
Cheap lacquers like rustolium will not hold up well to acetone, fuel, etc, and will take forever to fully cure. Definately dont use lacquer.
VXSXH20
Sionis Industries
Mid-Atlantic
Duplicolor/VHT are the same company, but It has been said the formulas are different on there engine enamel paints. I have used both on 3 different builds and have no issues to date. I ride freshwater so that may help immensely. I have DC metalcast on a set of cases along with VHT wrinkle black on the bed plates. again no issues. and have another motor all VHT gunmetal and black epoxy enamels. they are both good paints for the price. Prep is key. acetone and adhesion promoter help. but if your parts are bare aluminum you may want to use DC self etching primer.
None of the spray can paints have hardener in them which is why they tell you the part has to be heat cured.
I've painted v8s with acryllic enamel, looks nicer than spray can paint.
Good prep is everything
BruceSki
Formerly Motoman25
Long Island
Sandblast then use etching primer here. I paint them at work in between two large 600 psi boilers making 630 degree steam. I let them cure about 6 hours. Paint ends up rock hard and holds up great.
