Put in the water the other day and the prop is to big for the wear ring. We knew it was going to be close but not that bad. So we took the pump apart and worked the prop in with a little sanding and grinding. Spins good now and the gap is still so so close. Take 2 should be tomorrow if I have time.
thanks roo,
Yes my drive train issue was a head gasket, while the hole time i was fitting electronics. The ride plate screws pulled through 5 of 10 holes on the plate itself.
EME was aware of the problem and say it is a bad batch of ride plates. They made me a new one a shipped it today.
