- Wilmington, NC
I recently replaced the head. In the process I was going to go with the ADA head/girdle set up. However once I got it on I was not getting the compression I should have and found out my blaster has a 650 in it. I went back with the stock head and had the carb rebuilt. I got everything back together yesterday and it now starts fine, which was my previous problem but now it will not stop with the start stop switch.
I searched and saw a similar problem with the runaway engine issue however mine just idles unless I hit the gas, its not going wide open. It also will stop if I pull the plugs. When I start it, I use a method in the runaway engine thread to stop it bu hitting the stop button and wide open throttle.
I opened up the switch and it looks brand new. If I push the kill button down, I get no spark at the plugs. If I push the stop switch down, I still have spark. I even opened up the stop switch and hit the start button and I still have spark. How can that be?
