My starter has been randomly failing to engage the flywheel, so I pulled the cover to investigate. I'm curious if the rounded teeth on the bendix and flywheel gear would be enough to cause my intermittent starter spinning?
Everything else seems good, no play in the case bushings, bendix is nice and smooth, no signs of water intrusion.
What do you think?
Thanks.
What do you think?
Thanks.
