I got 2 batteries that used to crank the motor over fine to start. Its odd both are now not working. Now they might crank it for half a second then just makes a whirling noise. 1 battery is lithium the other is agm. Lithium battery got Cca of 290.
Both batteries are fully charged via my powerpoint chargers.
If i pull spark plugs out they crank motor over fine. Obviously no compression this way.
If i pull stator cover off straight after trying to crank. Bendix is locked into flywheel gears and starter motor gear is lining up with bendix. Tesing bendix spring in and out is working fine.
I put a brand new starter motor in and having the same issue.
If i crank it via my car battery for a v8 motor it cranks motor over just fine.
I am going to get my batteries tested for cca rating tomorrow. But it seems odd 2 batteries would die at same time.
Any ideas on this situation ???
