Super Jet Starter Not Engaging?
I just saw this, so hopefully I'm not too late, but: don't thread the puller bolts too far into the flywheel or you'll damage a coil. Check it to be sure before putting the flywheel back on so you're not pulling your hair out if you suddenly get some electrical problems...
iangdesign
Cats, lots of cats!
United States
A little heat helps as well, but don't hold it on there too long. Use nylon rope and not threaded rope in the cylinder, a ratchet strap end works in a pinch as well.
