- Adrian michigan
Hello! I own a 1990 superjet 650 square nose that was purchased at the end of last summer and it was having issues where it would only run for a few minutes before bogging down and dying out. I discovered that the base gasket between the block and crank case was missing a chunk and blowing oil out the side of the engine. I just completed rebuilding the engine and replaced the carburetor along with all of the seals however it still is having issues starting and I don’t know what is causing it. I know the compression is good at around 150. If anyone has more knowledge or knows what would cause this I would appreciate the help.
