Starting point jetting, Kaw 750/B pipe, sxr carbs
Crab
thanks darin...noswad!
Seattle
crab, your crossover on the carb manifold(balance tube) is filled right? that would mean if it wanst filled, i would need slightly larger jets, cuz of less air vaccum (signal) on each carb.
chokes are out? same as mine.
how many turns out are you on the LS and HS??
Chokes out, tube filled, about 3/4 on both high and low adjuster.
