- buffalo ny
Replaced the motor on 93 750sx small pin. Got it all in over the past weekend, was firing and running with gas poured down the carb. It was making a grinding sound when you hit the start button... figured it was the bendix being stuck a little. Buttoned everything up today and went to start it. Not firing at all and found zero spark! Pulled the cover and found that the stator was chewed up on the outside. Guess it wasn't the bendix that was making the noise! This is what it looked like
I also found these wedged in behind the flywheel and bottom of the cases. Any idea where these came from? .
Also any ideas on why this happened would be great. I have my old motor to look at and measure from. The measurements look to be ok
