- Belleville, MI
I am in the middle of acquiring parts for my square nose build. After I finish this SN build, I want to ride it and get more comfortable with tricks, then buy an aftermarket hull to practice tricks that would otherwise risk the SN hull.
I have 2 things I'm debating on right now.
1. Build this motor for the best result possible and potentially switch it to an aftermarket hull when I get one
2. Just keep it in the SN and get a new motor for the aftermarket hull- I wanted to use a 701 in the aftermarket for reliability and then change if I ever get good enough to need something more powerful
Is it even worth it to change the cylinders to 61x or should I just keep it simple and stick with the complete 62t for now?
Mods to the motor will be factory B-pipe limited, rrp water box, larger exhaust hose into a newer SJ through hull exhaust (I'm doing wide tray and replacing the foam so i might as well change it while I'm in there).
