So I've recently went from thrust trim to xscream trim and installed a new steering cable. Cable is a 96-07 and I'm using the xmetal cable extension on the steering cable. Issue is the steering on the pump end bottoms out and will not give full throw. I feel like it's only allowing about 45-50% throw to the right. The cable up top at the steering plate is not attached and the xmetal extension is adjusted all the way in to the max (i know there is more threads to go on the pic but it can't adjust in any further). The cable is ran correctly with the longer end on the pump side. I feel like this may be a easy fix and I'm just overthinking this situation. 2nd pic is the throw to the right and third pic is throw to the left. Any help would be great!
