Steering setup
For some reason my steering when I go to turn left for a setup wake doesn’t want to cut hard. Im not exactly sure what the issue is. Any help would be appreciated. I have a Tigercraft m1 with rrp ovp steering, a brand new cable. And xmetal trim with stock 62t nozzle
Quinc
Buy a Superjet
California
did you check if the nozzle will turn the same amount left and right? If not you need to adjust the fittings on the cables. Or add an extension depending on the trim/nozzle.
Quinc
Buy a Superjet
California
is it a new cable? The direction you install it matters.
I cant tell from the pics. Turn the steering all the way to the left and then the right and then adjust the steering cable ends to make them even. You also have to stop on the steering stop or the cable will break.
might wanna get a longer bolt and leave some room for the ball bearing to move around in. when trim lever is pulled it can damage/bend the cable. if you need me to I can show a pic of my setup
I think I still need a longer bolt lol
All the same, my hole might be lower than yours. Now that I think about it, top could possibly be better since it might not press against it as much with trim. Doesn’t matter to me though since I can’t ride until next year
