- mississippi
I just installed my cylinder and i used plenty of lubricant and i can see the pistin rings through the exhuast ports and all went on correct. My question is it normal for one of the cylinders to be abnormally stiff when turning by hand. the front piston moves almost effortlessly up and down like i would think it would. the rear piston gets stuck towards the top of the sleeve and you really have to lean into it to get it to ccomplete its stroke. i honed the sleeves and put in new rings. is this normal?
