Stingray's 1999 RN build
Stingray
Silver Billet Power
TN
Ok, couple pics of the the hull and engine compartment, then the foorhold process. Footholds are done, just needs some turfing.
Stingray
Silver Billet Power
TN
Two more, just had a lil fun with the last pic.
another from today. reinforcing handle pole area. Stingray is my uncle so im just posting a couple more pics up on his thread.
reinforcing handle pole area is done
reinforcement on the sides is done
on the handle pole area we used epoxy resin with 5 layers of glass, put foam in the holes on the sides
was 6mm thick, now its 11mm thick
on the sides we used did a layer or 18 ounce bi-axel, then a layer 6 ounce, and then 1 layer of 1X1 carbon fiber
keefer
T1
Tennessee
Lookin, good there RD. Matter of fact it looks so good, do you mind if I bring my roundie project hull over there and we can put the whammy reinforcement on my junk.:hail::biggrin:
sjetrider
Yeah, I will bring the project hull over and drop it off today too:biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggthumpup:
Stingray
Silver Billet Power
TN
Got Keefer's done last weekend and now FINALLY starting to put parts back on!!!! Found out that the lower brkt[blowsion] has to go on the UMI pole before the pole goes on the hull,& throw in a blowsion spring and it take two to wrestle all that together.Blowsion says to cut 3/8" off spring but it looks like it will need about 1" cut off,even though the brkt is only 5/8"shortened.Waterdawg hood hooks look like they will work fine with some longer bolts.
sjetrider
Its an awesome boat and Stingrays att: to detail is unreal. This will be a 200% better than new boat when done. The Carbon reinforcement looks killer and this boat has new paint top and bottom and I mean the entire bottom has like 6 coats of clear on it too. Major bling.
ok guys here's what goin down now
handle pole is on with the blowsion bracket, waterdawg hood hooks are on, waterbox is in, steering is put together.
