G
Goose
Guest
what is the stock compression of a 701 motor suspost to be at.i just put a motor togather that i got back from the machine shop they fitted the pistons.i put it togather and it seems like they rock in the bore a good but i dunno if im just seein things should they move a little bit or should they be tight,also i put a stock head cut down dunno how much its cut or didnt check the squish but it only read 150 in each cyl after the motor was ran to seat the rings.thats why i was wondering what stock compression was and if the pistons were too loose would be causing the compression to be low with a stock head
thanks alot
thanks alot
