- michigan
I bought the harmonic puller suggested from my local Advance auto. It fits perfectly. I tightened down and continued putting more tension on it for a week. I also occasionally tapped with a ball peen hammer. Flywheel did not move at all! I do not own an impact wrench/gun. I am concerned about damage to my crankshaft using a power impact. My ski runs well, and while I do want to lighten the flywheel, I really do not want to replace a damaged crankshaft, and would simply accept my Blasters performance instead. I do have a slide hammer that I have used on motorcycle flywheels, and it fits the harmonic puller perfectly. I will have to remove the fuel tank to try this, but wanted to find out if anyone else has had this stuck flywheel condition, and may have used a slide-hammer.
Chuck
Chuck
