Super Jet Such a great day!... Not.
Vumad
Super Hero, with a cape!
St. Pete, FL
A lot of people forget where they came from, and tell you to just drop money on anything and everything (maybe they just came from money and have always had it?). I know what it is like to be on a budget, and your budget is definitely in the tight category.
You have a great platform, don't get ahead of your self. "ride it until it dies" is pretty broad advice given because that thing may run for ever.
Sounds like you have a great platform. Don't let cosmetic issues make you think you have a bad ski. That poorly patch hole is unlikely to cause a problem, beach gouging is common and most stress cracks are just in the gelcoat (non-structural). That broken bolt in the flywheel cover is a non-issue as long as your electronics are staying dry. Someday worth fixing, but not worth buying a ski over. Don't reinforce that hull yet. Adding 10-20lbs of reinforcement you don't need will only keep you down in the water. You may never need to reinforce if you are not riding in the surf. Wait until you are starting to roll to worry about the sides of the engine compartment. You can avoid reinforcing the bole base for now (which you probably can't do with the motor in) by installing a limiting rope.
Don't mess with the jetting. If it runs good, the jetting is likely right. Ensure your tuning is right, and if it's not boggy or running lean, then any adjustments necessary can be likely be taken care of from the high/low screws. A 61x single carb will only run your $10 in jets, so it's not a big deal in any case.
Your hood issues can likely be patched. If you seal area is slightly damaged, maybe a ratching hood strap or just a new hood will help.
You have a good platform. I would just put the money into fixing worn out part. Cables for example, my RN has a broken cable, I got a kawi style cable and AM throttle to use it from JM for under $100. JM sold me a 10/18 stainless prop like mint for $75. I would put the extra money into front sponsons and a RN pole conversion.
Just take care of that thing, keep it clean and running nice, make minor repairs as you go, patch the hull here and there, and when the off season comes, yank your stuff, glass/patch/paint and reassemble. You'll have a nice looking ski. (I used a single stage selathane paint $13 pt from the fiberglass store and UV resistant clearcoat polyurathane from home depot shot from a $50 home depot gun and my hood came out great, except I was a little heavy on the clear and it sagged, it's very thin, so do several very thin coats).
I think for $500, you can fix you steering and replace the hood, with money left over for a prop, intake and sponsons, and if you are really thrifty, maybe even enough for a conversion bracket and RN pole. Money can go a long way when your smart with it and make the right friends.
Oh, last thing, go through your fuel system, make sure all your lines are clean, air tight, and your carbs are properly clean, working right and tuned. Goes a long way.
Edit: I like my sponsons, but they are pretty low on my upgrade list unless you plan to hit the bouy course. Shortening the pole (or getting a pole you can shorten) is much more valuable in the surf than sponson imho.
Edit again...: I have a RN, but only because I could afford a newer, more problem free ski, and because I wanted easy access to lowered hoods, poles and well, I liked the look. This is not in your budget, and quite frankly, a relative waste of money for you since the bottom decks are very similar and parts are interchangeable with each other and AM hulls. I bought a 2004 RN SJ in 2011, it was only ridden 3times/yr in brakish water, flushed the motor but not washed. I have since replaced the midshaft housing (WSM), rebuilt the carbs twice (SBT stuff sucks, buy mikuni kits), cracked my pole, broken my throttle cable, and so forth. Newer doesn't mean problem free, so just keep what you have going. My ski has of course gotten a lot more done, which you can see in my build thread via my sig, but my point was about reliability and maintenance, not upgrades. Newer stuff breaks too. Reliability above all else.
in regards to your O-rings...the kits sold are great specially for the thrust bearing, however i found the rubber ones break easily if any slop comes into play as they protrude and tear.
so, a quick trip to NAPA auto parts store and for a few bucks i now have a half dozen spare ones in the tool box both the large and small one...heck the even had the actual bearing in there too so i picked one up just to have it.
Roseand
The Weaponizer
Wisconsin
Sorry I haven't posted, I've been busy with work and stuff.
I'm definitely going to be making a limiting rope when I get a chance, and I'm ordering a steering cable from jetmaniac.
Thanks for the advice guys.. I've finally got my mind made up on what to do :). Thankfully the whole reinforcing idea is off of my mind.
I'll be fixing things as I go, and when it comes to winter I'll most likely buy another SN hull that's clean and build it the way I want it.
I need to do some fiberglass work to fix the hood, so I might do the hood mod too while I'm at it. Well, I should just buy fiberglass supplies to keep around if something happens! Otherwise, if someone's got a squarenose hood for cheap I'd take it too.
Yeah, I'm not so sure about tubbies now, but I'll be looking for an intake grate+ prop for sure. I appreciate the help sososososo much!!
Buckwild12
I'm moved by DASA power!
Tubbies don't make that big a difference in my humble opinion. Plus in many cases they mean holes in the side of the ski, if done improperly the foam fills with water, and worse case scenario, leak water into your hull.im a big fan of less holes to let water in is better.
tor*p*do
Squarenose FTW
NW NC
Yeah I weigh a little below 150.. so that helps. Isn't the SN pole mount area really weak, especially if I'm learning stabs though?
use a pole limiting rope to prevent over extending
and it will be fine
or fix it after it breaks
Vumad
St. Pete, FL
I race my Superjet too. I don't have a sxr because I also do flatwater and surf. I dislike my front sponsons for the flatwater. I have destroyers which are stupid heavy. I feel like they make the nose heavy and clumbsy. I don't like the way the nose feels and the pop doesn't feel right anymore off my setup wake, but I think that is the weight, not the sponson.
However, when it comes to racing, the ski is night and day. It nearly eliminated roll from side the side. The ski ride flat and true and is much more enjoyable to take a cruise on. The stability is vastly improved during high speed. They greatly improved cornering stability and hookup. I also used to have a huge problem in rough water where if I was parallel to a wave the ski was unridable, guarenteed to ditch me to one side or the other, but this too has been eliminated.
Sponsons hands down, undoubtly and unquestionably improve racing and rec riding extensively. My jury is still deliberating on flatwater, mostly because of the extra weight, but I feel in the long run the extra surface for pop and set up stability will negate the weight. I haven't ridden in the surf yet, and I have seen some sick riding on sponsonless superjets and much smaller skis that makes me unsure of the benefits of the sponsons. More people may use them just because more stability makes them more able, even if the ski is less capable.
In any case, for rec riding and racing, there can be no question about th value of front sponsons.
