- tampa florida
bump
You are partially correct on the sj shafts. You are wrong on the blaster shafts, and partially correct on couch shafts.The OEM sj and blaster shafts are made in 3 pieces.
I didn't waste 1 second reading any of your novel. You remind me of a msdnc fact checher. I wonder why. Lol. IDGAFSorry, I don't want to derail sj762's for sale thread. I will first say that this seller and the machining company are legit.
Correct -'90-07 OEM SJ shafts (and FX1) are all Tapered shafts, so they are made from 3 separate pieces which are all machined separately, and then fusion welded together. You can see the weld behind the splines where the shaft necks down, and the other weld is in just front of the threads for prop.
Incorrect - '08-20 OEM SJ shafts are all NON-Tapered shafts(like a couch), so since the spline end of driveshaft is all a constant diameter, they are only made from 2 separate pieces which are all machined separately, and then fusion welded together. You can see the weld is in just front of the threads for the prop.
Incorrect - '93-96 OEM B1 and 96-97 OEM B2 shafts are all NON-Tapered shafts(like a couch), so since the spline end of driveshaft is all a constant diameter, they are only made from 2 separate pieces which are all machined separately, and then fusion welded together. You can see the weld is in just front of the threads for the prop.
Correct - While most OEM Yami 2 stroke couch driveshafts are all 2 piece driveshafts like Blasters, there are some models which have extra hardened splines which are machined separately using different steel. So are not tapered, but have the extra weld beside the splines.
You're a character. The man comes in with some interesting advice, and that's your response?I didn't waste 1 second reading any of your novel. You remind me of a msdnc fact checher. I wonder why. Lol. IDGAF
Like i said I didn't read any of his novel. All I saw was true and false. This guy follows me around like a dog and tags me every time I make a general comment and thinks he's correcting me. I am a character and IDGAF anymore. I know what I know and I shouldn't even offer any of what I know to fux that dont appreciate it or listen. Obviously you're still on the neen to learn boat. Thankfully I'm not and over it. I dont need to be a teacher . Idgaf if I'm listened to or not. They'll learn. Maybe. I asked a simple question and got responses from guys I didn't ask to hear fromYou're a character. The man comes in with some interesting advice, and that's your response?
